OS Name/Version: ubuntu 22.04 lts
Product Name/Version: 2.4.0.4
Auth failure to remote server from controller
![Screenshot_1|690x130](upload://aEv8ZuJHnYNIbt4XfeyNzLqcBB4.jpeg)
![Screenshot_2|667x336](upload://ArngXxHYAUq3on0dPzvbUDoObvn.jpeg)
13:03:00
Authentication attempt for user AMP_SYSTEM from 192.168.1.143
13:03:05
TaskCanceledException
[0] (TaskCanceledException) : The operation was canceled.
at AMPAPI.RemoteInstance.GetResponseDynamic (String Module, String Method, Object Parameters) at AMPAPI.RemoteInstance+API_Core.Login (String username, String password, String token, Boolean rememberMe) at GSMyAdmin.Authentication.RemoteAMPAuth.Authenticate (m.Http.IHttpRequest Request, String Username, String Password, String Token, Boolean TokenRequested)
IOException
[1] (IOException) : Unable to read data from the transport connection: Operation aborted.
at Net.Sockets.Socket+AwaitableSocketAsyncEventArgs.ThrowException (Net.Sockets.SocketError error) at Net.Sockets.Socket+AwaitableSocketAsyncEventArgs.GetResult (Int16 token) at Net.Http.HttpConnection.FillAsync () at Net.Http.HttpConnection.ReadNextResponseHeaderLineAsync (Boolean foldedHeadersAllowed)
SocketException
[2] (SocketException) : Operation aborted
13:04:00
13:04:05
IOException
SocketException
unsure it was working last night and woke up thismore to make a ARk server and couldn’t
g’day mate , yes home hosted alll servers have static ip , above is from Target below is from controller
[02:55:00] [Auth Activity] : Authentication token for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of iceymidgit
[02:56:00] [Auth Activity] : Authentication token for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of iceymidgit
[02:56:00] [Core Error] : HttpRequestException
[02:56:00] [Core Error] : [0] (HttpRequestException) : Connection refused
[02:56:00] [Core Error] : at AMPAPI.RemoteInstance.GetResponseDynamic (String Module, String Method, Object Parameters)
at InstanceManagerPlugin.RemoteInstanceManager.Login (String username, String password, String token)
[02:56:00] [Core Error] : SocketException
[02:56:00] [Core Error] : [1] (SocketException) : Connection refused
[02:57:00] [Auth Activity] : Authentication token for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of iceymidgit
[02:58:00] [Auth Activity] : Authentication token for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of iceymidgit
[02:58:00] [Core Error] : HttpRequestException
[02:58:00] [Core Error] : [0] (HttpRequestException) : Connection refused
[02:58:00] [Core Error] : at AMPAPI.RemoteInstance.GetResponseDynamic (String Module, String Method, Object Parameters)
[02:58:00] [Core Error] : SocketException
[02:58:00] [Core Error] : [1] (SocketException) : Connection refused
[02:59:00] [Auth Activity] : Authentication token for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of iceymidgit
[03:00:00] [Auth Activity] : Authentication token for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of iceymidgit
[03:01:00] [Auth Activity] : Authentication token for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of iceymidgit
[03:02:00] [Auth Activity] : Authentication token for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of iceymidgit
[03:03:00] [Auth Activity] : Authentication token for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of iceymidgit
[03:04:00] [Auth Activity] : Authentication token for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of iceymidgit
[03:05:00] [Auth Activity] : Authentication token for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of iceymidgit
[03:06:00] [Auth Activity] : Authentication token for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of iceymidgit
[03:07:00] [Auth Activity] : Authentication token for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of iceymidgit
[03:08:00] [Auth Activity] : Authentication token for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of iceymidgit
[03:09:00] [Auth Activity] : Authentication token for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of iceymidgit
[03:10:00] [Auth Activity] : Authentication token for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of iceymidgit
[03:11:00] [Auth Activity] : Authentication token for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of iceymidgit
[03:12:00] [Auth Activity] : Authentication token for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of iceymidgit
[03:13:00] [Auth Activity] : Authentication token for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of iceymidgit
[03:14:00] [Auth Activity] : Authentication token for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of iceymidgit
[03:15:00] [Auth Activity] : Authentication token for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of iceymidgit
[03:16:00] [Auth Activity] : Authentication token for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of iceymidgit
[03:17:00] [Auth Activity] : Authentication token for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of iceymidgit
[03:18:00] [Auth Activity] : Authentication token for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of iceymidgit
[03:19:00] [Auth Activity] : Authentication token for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of iceymidgit
[03:20:00] [Auth Activity] : Authentication token for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of iceymidgit
[03:21:00] [Auth Activity] : Authentication token for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of iceymidgit
[03:22:00] [Auth Activity] : Authentication token for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of iceymidgit
[03:22:00] [Core Info] : Checking for AMP updates...
[03:22:01] [Core Info] : AMP is up-to-date.
yes my controller is R Pi and remote is ubuntu server is HP DL180 , it was fine until they did a reboot for a security update last night
the remote just repeats
00:59:05
IOException
SocketException
YES i can create a instance on remote system without controller but i can’t manage it, as it says please connect to your controller at http:// blah to manage this instance
it is like to connection times out every so often and it can’t connect as i can create a instance on windows server and sometimes manage it and sometimes not only been having these issue after the 2.4 update
