Connectivity Problem with TShock - PROBLEMA CON LA VERSION DEL TSHOCK
Application TShock
There is a version mismatch between the TShock server and the Terraria client. The server is currently running a specific version of TShock compatible with Terraria 1.4.4.9, while the Steam client automatically updates to the latest available version of the game.
Due to this discrepancy, the client is unable to establish a connection with the server, as Terraria enforces strict version matching between client and server during the handshake process.
Observed Behavior
  • Server starts correctly and remains in a Ready state.
  • Client attempts to connect using server IP and port.
  • Connection is rejected with a version mismatch error.
  • Terraria client version differs from the server-supported version.
Expected Behavior
  • Client and server should run compatible versions to allow a successful connection.
  • INICIAR EL SERVIDOR
  • INICIAR EL JUEGO Y PONER LOS DATOS DEL SERVIDOR
  • MENSAJE EN PANTALLA DE VERSION DEL JUEGO ES DIFERENTE AL SERVIDOR.
A 1.4.5 version of TShock doesn’t exist yet: Support for Terraria version 1.4.5.0 · Issue #3159 · Pryaxis/TShock · GitHub
Also, English only in this forum
