Connectivity Problem with Satisfactory - failed to connect to server api
Application Satisfactory
Hi im trying to access the servermanager it says the servername pending and the ping to the server but it says failed to connect to server api.
if I start the server via the exe in the amp folder it works without issues. but i want to start it via amp.
  • add instrance
  • update instance
  • start instance
