What happens if you use the Steam server browser and connect via the query port? The “Connect to server” button should also have a sane link here.
Try clicking the little ‘link’ icon, it’s a steam://connect URL that should pop up the steam browser.
I did that and it didn’t do anything
Ah, replace 0.0.0.0 with your IP ![]()
And where is that? ![]()
If you’re playing on the same system that AMP is running on you can use localhost, otherwise its your internal/external IP.
Well, yes, but where do I change it, because since I have ARK it normally runs
I don’t follow? You don’t change it - applications should be listening on 0.0.0.0.
What? The ports are correct, the IP on the ports is also correct
I’m not following you at all right now xD what are you trying to do at this moment?
Well I’m still trying to connect to the server somehow
Try Client.connect using the query port instead of the game port.
I meant in game, using the console.
That doesn’t work either, it keeps saying the same thing
Rust Console 4.0
Manifest Assets Loaded
117 skinnable objects
Playing Video D:/SteamLibrary/steamapps/common/Rust/RustClient_Data/StreamingAssets/MenuVideo/attackhelicopter.mp4
client.connect 192.168.0.1:28015
Found 0 server query results, attempting direct connect…
Connecting: 192.168.0.1:28015 (Raknet)
Connecting: 192.168.0.1:28015 (Steamworks)
Disconnected (Disconnected) - returning to main menu
got title filename: D:\SteamLibrary\steamapps\common\Rust\temp\6e47fe6acb1bf6adbaab7cfb705d02e3.png
Playing Video D:/SteamLibrary/steamapps/common/Rust/RustClient_Data/StreamingAssets/MenuVideo/nukesilo.mp4
client.connect 192.168.0.54:28015
Connecting: 192.168.0.54:28015 (Raknet)
Connecting: 192.168.0.54:28015 (Steamworks)
got title filename: D:\SteamLibrary\steamapps\common\Rust\temp\d9150061f7e9da93cede242f531438c8.png
Using the query port. 27016.
Query Port 28016-------------------
Sorry I meant 28016. Either way try connecting using that port in game.
