Connectivity Problem with Palworld - Failed to connect to the server say connection timed out
Application Palworld
Server and everything seem to be running fine since yesterday but when I woke up today it say that server connection timed out tired updating and restarting the server but doesnt semm to work
  • Restarted server > Updated palworld > server connection timed out
  • Tried to update the instance and still cant work
  • Made sure every connection is running stopped the server and started it again while making sure palworld is updated still cant connect
Did the IP of the server change?
As far as I know ntg changed
You should be able to check the IP to confirm. Without more info, not going to be able to get any fix.
Confirm the server is running and get the IP. Ping it directly and see if it responds. Are you on a LAN with the server? If so, make sure you are using the local IP to verify a connection first.
Hmmm well turns out its just me having issues which idk what to fix rn… my friends can join the server just fine
