Connectivity Problem with Palworld - Can't join palworld server connection timed out
Application Palworld
today i try to join my palworld server. it shows connection timed out, when i check on hostinger the server still running no indication of idle. I try to restart some of time it did not fix it. second person also try to join and had same problem. Then we try to use DNS or VPN still no result.
  • server running as usual
  • i try to join my server using same port as before
  • it always shows same error even using VPN or DNS did not solve it
  • second person try to join and still get the same error
Sounds like a Hostinger issue that you should contact them (unless your session doesn’t have enough memory to run it correctly).
