Connectivity Problem with Minecraft - too high cpu usage and server not starting
Current State Starting
vps cpu usage reaches more than 150%, i try to run the server and it takes over 30 minutes and when in the lag is unimaginable.
  • players joined the server and found it laggy
  • close the vps
  • start the vps
If you’re with Hostinger, you’ll have to contact their support, this is the forum for AMP.
If I were to guess you’re probably running a modpack that the VPS just isn’t rated for.
