Connectivity Problem with Minecraft - I can't find the server after running the server
After the restart, port 2224 and port 25565 are green
  • installing the server
  • update the server
  • ports added in the modem. after starting the server
  • server restarts
I’d suggest double checking that you’re using the right IP, that the server is running, and that you’ve port forwarded correctly.
You can use a site like this one to double check external connectivity, as sometimes you’re unable to connect to your own public IP.
https://mcsrvstat.us/
hello, thank you very much. but I still can’t get a connection I use 192.168.1.10:25565 in my router. this is also the address amp told me. but AMP runs via UNRAID so I don’t know if more needs to be done in terms of opening ports. I can’t find anything about it anywhere either. it is becoming a high irritation factor. I hope there is someone who can help me with this
If you’re running AMP using the unofficial unraid docker image, that isn’t supported here due to a variety of common networking hiccups, it’s suggested that you run AMP in a VM on unraid (with the VM’s networking in bridged mode)
It already works thanks for your help
