Connectivity Problem with Minecraft - Errormessage: Authentication Servers are down. Please try again later. Sorry!
I try to fix it with ChatGpt.
So I have tryed ping the sever (Doesnt work),
edit the /etc/resolv.conf,
disaple the Ipv6,
tryed the dig command (chatgpt said worked),
tryed with IPTables (Chatgpt said nothing blocked).
Please help.
  • started the homeserver
  • started the mc server
  • tryed to connect local and with playit
  • get errormesage
Try setting the MC instance’s Startup mode to Do nothing, then stop+start the MC instance from the main panel page. Then try starting the MC server and see if you run into the same issue.
