Field | Value |
Operating System | Linux - Ubuntu 20.04.6 on x86_64 |
Product | AMP ‘Decadeus’ v2.4.6.0 (Mainline) |
Virtualization | None |
Application | Minecraft |
Module | MinecraftModule |
Running in Container | No |
Current State | Sleeping |
Hello, I’ve been trying for a few days to get this minecraft java server working. This is for internal LAN use only… It’s driving me crazy as it appears everything is setup properly. I currently run mine-os Node and also just a regular docker minecraft server. Both of these work perfectly fine. This confirms there isn’t some kind of firewall issue or something else from the client blocking me to the backend server. all of this is running on unRAID Docker, connecting to same backend server… It appears this issue is specific to the AMP server… I have confirmed the IP and port are correct, all statues are green, no errors in the logs etc… Whatelse could I possibly check as to why this isnt connecting? Thanks!
- Checked Running Status
- Checked Firewall
- Confirmed IP and Port
