Connectivity Problem with Minecraft - Cant Connect wit the endpoint
Hi
I have tried to connect via srv616022.hstgr.cloud:25565 wich is the stated endpoint and also the port is correct int server.json
I have installed the server localy first to verify if everything works. than I Changed the Server to NeoForge in the correct version and uploaded the files. Finally I started the server.
Mod Pack: All The Mods 10
still i cant find the server may your able to help me?
  • put srv616022.hstgr.cloud:25565 in the join server prompt in minecraft
  • connection no work
Just to note, this is not Hostinger support.
Try double checking whatever DNS settings Hostinger has if they have them, otherwise try the actual IP of the VPS and not the domain.
Are you forwarding the port? If you aren’t, it definitely won’t work.
Hostinger runs on VPSs, the end users don’t have access to port forwarding
