Connectivity Problem with Minecraft Bedrock - Minecraft Bedrock NetherNet UDP ports waiting for network traffic
Product AMP ‘Proteus’ v2.8.0.10 (Mainline)
Virtualization Podman
Application Minecraft Bedrock
The Minecraft Bedrock instance runs and accepts direct IPv4 connections on port 19132. However, the “NetherNet UDP Transport Ports” (19134-19153) remain stuck in a “Waiting” state in the Metrics and Status dashboard.
External tunneling services (such as playit.gg, which works correctly with other game instances on the same host) are unable to route traffic because AMP is not opening or binding the NetherNet UDP port range properly on Linux. Note that the host firewall (UFW) is completely disabled, so OS-level blocking is ruled out.
Is there a specific configuration or network binding setting in AMP to force the Bedrock server binary to bind and listen on the NetherNet UDP transport ports?
  • Create and start a Minecraft Bedrock instance on a Debian Linux host.
  • Open the “Metrics and Status” dashboard for the instance in AMP.
  • Observe the “Network Port Status” panel for the NetherNet UDP ports (19134-19153).
