Connectivity Problem with Minecraft Bedrock - Cant join server for mobile device
Application Minecraft Bedrock
Hi, my Minecraft Bedrock server (AMP, srv2075458.hstgr.cloud:19132, BDS 1.26.52.3) is unreachable for most clients. Players on iPhone (iOS 1.26.52) and Windows (1.26.52) get “NetherNet – Error Detail InitialConnection-13” and cannot join. This happens on WiFi and mobile data, with the hostname and with the IP directly (187.77.148.52:19132), with both Transport=NetherNet and Transport=RakNet, and with all add-ons removed. One friend’s Windows PC on 1.26.5x can join with the same address. The panel shows IPv4 19132 as Listening, and the server log shows “Accepting clients on [::]:19132”. Can you confirm that UDP 19132 (and 19133) is open from the internet to my server, with no filtering on the network side?
  • ▎ 1. In Minecraft Bedrock 1.26.52 (iOS or Windows), go to Play → Servers → Add Server.
  • ▎ 2. Enter address srv2075458.hstgr.cloud (or 187.77.148.52), port 19132.
  • ▎ 3. Select the server and press Join.
  • ▎ 4. The error appears immediately, before the world loads.
  • Already tried: WiFi and mobile data; hostname and direct IP; Transport = NetherNet and RakNet (server restarted each time); all add-ons removed from the world The result is the same every time.
Hi, just to make sure you’re aware - we’re not your host. This is the support for the control panel.
Does the games log show anything when you try and connect? Does AMP show both ports are open and listening?
Thanks. To answer your questions:
  1. Does AMP show both ports open and listening? Yes. With Transport = NetherNet, the panel shows IPv4 19132 as Listening, IPv6 19133 as Not Listening, and NetherNet UDP 19134-19153 as Waiting. The bedrock_server process listens on TCP *:19132. iptables and ip6tables INPUT policy is ACCEPT, so nothing blocks it. Hostinger confirms no firewall group is attached to the VPS.
  2. Does the game log show anything on connect? When the failing clients connect, the AMP console shows nothing at all. When a working client (a Windows laptop) joins, the console shows the join normally. On the VPS, tcpdump shows the failing client completes the TCP handshake to port 19132, sends about 1.5 KB, and the server replies with 7 bytes and closes the connection. From outside, “curl http://187.77.148.52:19132/” returns “404 Not Found” (plain HTTP), but “curl -k https://187.77.148.52:19132/” fails with “handshake failure”. So the failing clients seem to attempt TLS, but the server only accepts plain HTTP.
What I tried: switching Transport to RakNet. With direct IPv4, the server replies with 33-byte packets but clients never complete the connection. The server log also says “NetherNet is the only supported transport type” in this release. So neither transport works for these clients, while one Windows PC on the same version joins fine. Players on iOS and Windows 1.26.52 get “NetherNet - InitialConnection-13”.
Is this a known issue with BDS 1.26.52.3 under AMP 2.8.0.8, and is there a recommended server version or setting? Diagnostics are attached (Updates > Diagnostics > Copy data to clipboard).
