Connectivity Problem with ARK: Survival Ascended - I can't find any of the hosted servers
Application ARK: Survival Ascended
Hello,
I wanted to host an ASA server.
installation went smoothly. Everything turns green but I can’t find the server in the server list. I renamed the server to make it easier to find.
Then I installed a Minecraft server and I can’t find it either.
Then I can’t find a CS2 server either. I have released all ports
TCP32400
UDP27015
TCP27015
TCP7777 - 7787
TCP8885 - 8895
TCP27020 - 27030
UDP7777 - 7787
I’ve reinstalled everything several times and can’t find a solution.
Minecarft, for example, is running on another server in the network and is accessible
I’ve already tried the whole thing on a VM with the same result
  • all necessary ports released
  • restart -Router -Server -PC
  • everything reinstalled
  • Looking for a solution on the internet
  • ports changed
I have the same problem, Minecraft’s servers work perfectly, but in Ark’s case even if he has the ports open he can’t find it.
