Connectivity Problem with Application Deployment - connecting from local network with https
Product AMP ‘Decadeus’ v2.4.5.0 (Mainline)
Hello, I’m having troubles to connect to the server from the same network. My networking is set up with DMZ (if that makes it impossible to fix i can change that) and https. I am able to connect to it with another external ip or a vpn so its definitely an NAT loopback thing but i have no idea how to fix it (router does not support hairpin NAT…)
thanks for your help!
  • install debian 12 minimal services
  • install amp with https
  • open the https address from local network
