Cryo
1
| Field |
Value |
| Operating System |
| Product |
AMP ‘Phobos’ v2.6.3.0 (Mainline) |
| Virtualization |
Docker |
| Application |
Palworld |
| Module |
GenericModule |
| Running in Container |
Yes |
| Current State |
Ready |
I cant create more than 1 base even though i have the setting set to 5.
- I changed the max number of bases to 5
- I can still only create one base.
- I tried again
Where did you change the setting?
Cryo
3
I changed the setting in the Hostinger game panel.
Did you restart the server after doing so?
Cryo
5
Yes i did, twice. It has yet to change.
Do you have a WorldOptions.sav file in your saves directory?
Cryo
7
I have a palworldsettings.ini. Is that it?
system
Closed
8
