| Product | AMP ‘Deimos’ v2.7.2.8 (Mainline) |
| Virtualization | Docker |
| Application | Assetto Corsa |
| Module | GenericModule |
| Current State | Failed |
Hello, If you change what car(s) you have selected via the AMP UI it will successfully change the server_cfg.ini, but it does not successfully change the entry_list.ini file, which requires each car listed manually.
- Setup AC server instance normally.
- Change what car you have in the car selection
- Attempt to start server after changing car. Error shows.
