Conan Exiles Update Issue
OS Name/Version:Ubuntu 22.04 and Win Server 2019
Product Name/Version: AMP 2.4.4
Problem Description:After updating to the latest Steam Patch, Conan Exiles Dedicated Server will not launch. Console shows update applied, then
`wine: cannot find ‘./ConanSandboxServer-Win64-Test.exe’
Update Conan Exiles server - broken after update
Actions taken to resolve so far: Attempted to create new server instance just in case, updated existing instances on two separate servers, same results.
The template has been updated.
Fetch Latest under Configuration->Instance Deployment. Then create a new instance
Or after Fetch Latest, you can update an existing existence by right click on it, Refresh Configuration
