OS Name/Version: Master (Hybrid instance) = Ubuntu 20.04.3 LTS | Target instance Windows Server 2019 (Build 1763.2628)
Product Name/Version: AMP Release “Triton” v2.3.2
I run a hybrid instance under Linux on one server which works without problems. Now I want to implement a target instance on another server that runs under Windows. I have installed it under Windows and configured it as a target server with reference to the master under http://ip-master:8080.
The instance is also visible in the master and game servers can be installed. But after the installation the servers can not be started. Is the error known ? What can I do to fix the error?
Fresh Install AMP Target instance on WIN 2019 Server and Connect to Master
Actions taken to resolve so far: Rebuild Target instance
Can be closed missing DLL files from an old directx were the cause.
