Hello!
Everytime I tried to create an instance i’ve got the error : This task could not be completed: Create instance - Minecraft - State: 3.
What should I do to solve this problem? The version of AMP is 2.6.3.
Thank you!
Hello!
Thank you!
What does the deployment log say?
Non-managed instances exist, autoconfigure cannot guarantee that the configuration is valid!
HttpRequestException
[0] (HttpRequestException) : Resource temporarily unavailable (cdn-downloads.c7rs.com:443)
at Net.Http.HttpConnectionPool.ConnectToTcpHostAsync(String host, Int32 port, HttpRequestMessage initialRequest, Boolean async, CancellationToken cancellationToken) at Net.Http.HttpConnectionPool.ConnectAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at Net.Http.HttpConnectionPool.CreateHttp11ConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at Net.Http.HttpConnectionPool.AddHttp11ConnectionAsync(QueueItem queueItem) at Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken) at Net.Http.DiagnosticsHandler.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at Net.Http.HttpClient.GetStringAsyncCore(HttpRequestMessage request, CancellationToken cancellationToken) at ModuleShared.VersionManifest.FetchAsync(String forPlatform)
SocketException
[1] (SocketException) : Resource temporarily unavailable
at Net.Sockets.Socket.g__WaitForConnectWithCancellation|285_0(AwaitableSocketAsyncEventArgs saea, ValueTask connectTask, CancellationToken cancellationToken) at Net.Http.HttpConnectionPool.ConnectToTcpHostAsync(String host, Int32 port, HttpRequestMessage initialRequest, Boolean async, CancellationToken cancellationToken)
SocketException
Create Instance Failed: The core archive failed to download or unpack: Failed to find a release matching the specified version: Mainline/ - This version may no longer be available to download, you should update to a newer version.
Usual causes:
Hello!
Thank you for your fast support. You know your products very well.
