OS Name/Version: Ubuntu 22.04.2
Product Name/Version: “Decadeus” v2.4.3
Problem Description: Target fails Authentication to Control
[15:35:03] [Core Error] : at AMPAPI.RemoteInstance.GetResponseDynamic (String Module, String Method, Object Parameters)
at AMPAPI.RemoteInstance+API_Core.Login (String username, String password, String token, Boolean rememberMe)
at InstanceManagerPlugin.RemoteInstanceManager.Login (String username, String password, String token)
[15:35:03] [Core Error] : SocketException
[15:35:03] [Core Error] : [1] (SocketException) : No route to host
[15:35:03] [ADS Info] : Failed to update Megawatt - Could not connect to the remote instance at http://192.168.1.64:8080/. Host Unreachable
[15:36:00] [Auth Activity] : Authentication token for AMP_SYSTEM requested by UpdateRemoteInstancesList on behalf of technovibe
[15:36:03] [AMPAPI Error] : Failure parsing API response
[15:36:03] [Core Error] : HttpRequestException
[15:36:03] [Core Error] : [0] (HttpRequestException) : No route to host
[15:36:03] [Core Error] : at AMPAPI.RemoteInstance.GetResponseDynamic (String Module, String Method, Object Parameters)
[15:36:03] [Core Error] : SocketException
[15:36:03] [Core Error] : [1] (SocketException) : No route to host
I am unsure on the steps to reproduce this, sorry
I have tried restarting the target which seems fine for a day or a few hours. After logging off and coming back to it The controller shows this and I can’t seem to get to the target. These are fairly fresh AMP setups.
