Arma 3 - is there a way to clone an instance
Application Arma 3
    1. build an instance and get it configured,
    1. ummm …
    1. multiple instacnes up and running with limited config nessary
There isn’t a solid way to clone an instance at the moment (that I know of).
Best bet might be to make a new instance, copy all the files over, then double check that all the AMP configs are the same (otherwise the configs will be overridden by the defaults in AMP)
