Application State: Preparing to start
OS Name/Version: Ubuntu 22.04.2 LTS (GNU/Linux 5.15.0-60-generic x86_64)
Product Name/Version: AMP version 2.4.3.0
Problem Description: Minecraft Instance: Application State: Preparing to start
  • Start Instance
If you shut down instance and start it again it will work. But inside the instance I cant trigger a “retry” or “stop/start”
See the log below. It might be because of the Forgecheck?
How do I solve this inside the Instance.
[14:20:13] [Core Info] : Starting AMP version 2.4.3.0 (Decadeus), built 14/03/2023 23:15
[14:20:13] [Core Info] : Stream: Mainline (Release) - built by CUBECODERS/buildbot on CCL-DEV
[14:20:13] [Core Info] : Running in a QEMU KVM environment.
[14:20:13] [Logger Info] : Deleting 8 old log files…
[14:20:13] [Core Info] : OS: Linux / x86_64
[14:20:13] [Core Info] : CPU: AMD EPYC 7702P 64-Core Processor (6C/6T)
[14:20:13] [Core Info] : RAM: 16001MB
[14:20:13] [Core Info] : AMP Instance ID: 9d079a34-30e4-4da1-ba4a-d0734eeedd20
[14:20:14] [Core Notice] : Running as McMyAdmin 3
[14:20:14] [ModuleLoader Info] : Loaded MinecraftModule version 1.0.0.3 by CubeCoders Limited
[14:20:14] [Core Info] : Metrics publishing is enabled at udp://127.0.0.1:12820.
[14:20:14] [ModuleLoader Info] : Loaded FileManagerPlugin version 1.0.0.0 by CubeCoders Limited
[14:20:14] [ModuleLoader Info] : Loaded EmailSenderPlugin version 1.0.0.0 by CubeCoders Limited
[14:20:14] [ModuleLoader Info] : Loaded WebRequestPlugin version 1.0.0.0 by CubeCoders Limited
[14:20:14] [ModuleLoader Info] : Loaded LocalFileBackupPlugin version 1.0.0.0 by CubeCoders Limited
[14:20:14] [ModuleLoader Info] : Loaded CommonCorePlugin version 1.0.0.0 by CubeCoders Limited
[14:20:14] [Core Info] : Licence Present: McMyAdmin Professional Edition
[14:20:14] [FileManager Notice] : Using keypair with fingerprint 3n45+OBrPNtlkekDA5pFzq3ukd06KFv8W8iDUVYzu0w=
[14:20:14] [FileManager Info] : SFTP Server started on 0.0.0.0:2230
[14:20:14] [WebServer Info] : Websockets are enabled.
[14:20:14] [WebServer Info] : Webserver started on http://127.0.0.1:8087
[14:20:14] [Logger Warning] : RouterTimer@10Hz with 2 jobs started
[14:20:14] [Core Info] : Checking for AMP updates…
[14:20:14] [Minecraft Info] : Java located at /usr/lib/jvm/temurin-17-jdk-amd64/bin/java
[14:20:14] [Minecraft Error] : Process configuration failed. AMP wasn’t able to query the Forge version list. Please try again later.
[14:20:14] [Core Info] : AMP is up-to-date.
[14:20:18] [Minecraft Info] : Modpack cache is up-to-date.
[14:20:26] [Core Activity] : Authentication attempt for user amp from 127.0.0.1
[14:20:27] [Core Activity] : Authentication success
[14:24:30] [Core Activity] : Authentication attempt for user amp from 127.0.0.1
[14:24:30] [Core Activity] : Authentication success
Best regards
Quenaros
