OS Name/Version: Windows 10
Product Name/Version: AMP Instance Manager v2.4.0.6 built 30/09/2022 14:13
Problem Description: I go to launch AMP and it brings me to the web UI but the actual application hasn’t launched. I open it as administrator and install the main instance as a service and run it and it finally launches. But when I go to run any instances inside it says I dont have permission since it’s owned by whatever. I try using CMD to get it to launch correctly and it still won’t launch unless its As a Service.
Also the AMPInstance1-ADS version says its 2.4.0.8
The other instances I have show Version 2.4.0.6 and I try to update them and nothing.
Actions taken to resolve so far: I used CMD to try and update the instance. Nothing.
Tried CMD to Launch the program. Nothing.
Software can only be Launched As a Service but then I can’t start any instances.
Tried removing and reinstalling AMP. Nothing. Same issue as before.
