AMP web portal not available
I can no longer access the AMP web interface via http://serveraddress:8080
The log for the ADS01 instance shows:
[18:23:02]
[18:23:02]
[18:23:02]
[18:23:02]
[18:23:02]
[18:23:02]
[18:23:02]
[18:23:02]
[18:23:02]
[18:23:02]
[18:23:02]
[18:23:02
[18:23:02]
18:23:02]
[18:23:02]
[18:23:02]
[18:23:02]
[18:23:02]
[18:23:02]
B:23:02]
8:23:02]
8:23:02]
[18:23:02]
No stash entries found
fatal: unable to access 'https://github.com/CubeCoders/AMPTemplates.git/': Could not resolve host: github.com
[18:23:02]
[18:23:02]
[18:23:03]
18:23:03]
[18:23:03]
[18:23:03]
[18:23:03]
[18:23:03]
at Net. Http.HttpConnectionPool.ConnectAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at Net. Http.HttpConnectionPool. CreateHttp11ConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at Net. Http. HttpConnectionPool.AddHttp11ConnectionAsync(QueueItem queueItem)
at Net. Http. HttpConnectionPool. SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken can
at Net.Http. RedirectHandler. SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at Net.Http.HttpClient. GetStringAsyncCore(HttpRequestMessage request, CancellationToken cancellationToken)
at ModuleShared. VersionManifest. FetchAsync(String forPlatform)
[18:23:03]
[18:23:03]
[18:23:03]
at Net. Sockets. Socket. <ConnectAsync>g __ WaitForConnectWithCancellation | 285_0(AwaitableSocketAsyncEventArgs saea, ValueTask connect Task, CancellationToken can
at Net. Http. HttpConnectionPool. Connect ToTcpHostAsync(String host, Int32 port, HttpRequestMessage initialRequest, Boolean async, CancellationToken cancellati
[18:23:03] [System Warning/12]
otAve-AMPA1: /home /amn/ amndata/ins+
[Program Info/1]
[Program Info/1]
[Program Info/1]
[Program Warning/1]
[Program Info/1]
[Program Info/1]
[Program Info/1]
[Program Info/1]
[Core Info/1]
[Loader Info/1]
[Loader Info/1]
[Loader Info/1]
[Loader Info/1]
[Loader Info/1]
[Loader Info/1]
[Loader Info/1]
[Loader Info/1]
[Loader Info/1]
[Loader Info/1]
[ADS Info/1]
[Loader Info/1]
[System Info/12]
[System Info/12]
: Starting AMP version 2.6.5.2 (Phobos), built 28/01/2026 16:00
: Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
Running in a VMware environment
Current time zone is set to Central European Standard Time - It is recommended you switch to UTC+0 to avoid time-zone relat
: OS: Linux / x86_64
CPU: QEMU Virtual CPU version 2.5+ (4C/4T)
RAM: 7947MB
: AMP Instance ID: ac49fc99-0107-4681-9b2c-7b3b92f18fb8
: Loaded ADSModule version 2.6.5.2 by CubeCoders Limited
Loaded FileManagerPlugin by CubeCoders Limited
: Loaded EmailSenderPlugin by CubeCoders Limited
Loaded WebRequestPlugin by CubeCoders Limited
: Loaded WebhookPlugin by CubeCoders Limited
Loaded CommonCorePlugin by CubeCoders Limited
ADSModule requests dependency InstanceManagerPlugin
Loaded InstanceManagerPlugin by CubeCoders Limited
ADSModule requests dependency SystemUserManagerPlugin ..
: Loaded SystemUserManagerPlugin by CubeCoders Limited
: Loaded steamcmdplugin by CubeCoders Limited
ADS startup complete in 51ms
Updating remote source CubeCoders/AMPTemplates:main
: Updating existing remote source https://github.com/CubeCoders/AMPTemplates.git ...
[System Warning/12]
[Loader Notice/1]
[Loader Info/1]
[Core Info/1]
[System Info/11]
[Core Error/12]
[Core Error/12]
[Core Error/12]
: Failed to update CubeCoders/AMPTemplates:main
Using keypair with fingerprint 30y4eIk1cQi+aBbN/+Uub4POWe j9pt+WJsJDocZeB/I=
: SFTP Server started on 0.0.0.0:2223
Checking for AMP updates.
HttpRequestException
[0] (HttpRequestException) : Resource temporarily unavailable (cdn-downloads.c7rs.com: 443)
at Net. Http. HttpConnectionPool. Connect ToTcpHostAsync(String host, Int32 port, HttpRequestMessage initialRequest, Boolean>
[Core Error/12]
[Core Error/12]
[Core Error/12]
: SocketException
: [1] (SocketException) : Resource temporarily unavailable
at Net. Sockets. Socket. AwaitableSocketAsyncEventArgs. ThrowException (SocketError error, CancellationToken cancellationToke)
: Unable to query version information.
  • I’ve tried to do the ampinstancemgr reactivate,
  • tried to reboot the server
