OS Name/Version: Debian 10 with Game Panel
Product Name/Version: AMP 2.4.0.6
provides syntax highlighting.
- Attempted to update from GUI ‘Update Now’ option, says its updating, restarts, and comes back as same version asking to update
- SSH into the Linux server and ran ampinstmgr upgradeall - looks like its updating, but it doesn’t
- Logged in as root, switched over to amp user, (sudo su -l amp) and then ran ampinstmgr --nocache upgradeall - same result, looks like its updating, nothing changed
- repeated step above but after switching to amp user, ran ampinstmgr stopall then ran the ampinstmgr --nocache upgradeall command and rebooted the server - no changes
- also saw someone say maybe it was too out of date so I ran sudo apt-key adv --fetch-keys https://repo.cubecoders.com/archive.key
Actions taken to resolve so far: see steps to reproduce…
example of output from running the updates via command line
[Info] AMP Instance Manager v2.4.0.6 built 30/09/2022 14:13
[Info] Stopping Instance: ‘ADS01’
[Info] Stopping instance ADS01…
[Info] Requesting soft-stop…
[Info] Waiting for instance to stop…
[Info] Instance ADS01 has stopped.
[Info] Upgrading instance ADS01
[Info] Skipping cache and downloading fresh copy…
[Info] Downloading AMP from https://cubecoders.com/Downloads/LTS/AMP_Latest_LTS.zip…
[Info] Complete
[Info] Upgrade successful
[Info] Waiting for AMP instance to start…
[Notice] AMP instance ADS01 is now running.
[Info] Stopping Instance: ‘myinstancename’
[Info] Stopping instance myinstancename…
[Info] Instance myinstancename has stopped.
[Info] Upgrading instance myinstancename
[Info] Using cached archive: /home/amp/.ampdata/instances/AMPCache-LTS-20220930-123248.zip
[Notice] AMP instance myinstancename is now running.
[Info] Start for instance ADS01 was requested, but it is already running.
[Info] Start for instance myinstancename was requested, but it is already running.
I removed my instance’s actual name and replaced with myinstancenam
