Hello there everyone!
I used: https://config.getamp.sh/ to try to create both a json and kvp file for Windward, it is not showing in the “Create instance” box, how do I go about troubleshooting as to why?
Thanks in advance,
~ David.
Thanks in advance,
~ David.
Let me start by saying, that site is being heavily reconstructed right now. Mainly due to all the new features and how AMP functions has changed since it was released. So YMMV using it.
That being said, if you put the files under ADS/Plugins/ADSModule/DeploymentTemplates/CubeCoders-AMPTemplates
then go under Configuration->Instance Deployment and Fetch the latest. Refresh your browser and it should show.
