OS Name/Version:Windows 11
Product Name/Version: AMP Release “Triton” v2.3.2.4, built 22/02/2022 10:57
After update no Instance Specific Settings are shown only if I connect to the instance directly and not over The Main Instance.
Mike
#2
Have you emptied your browser cache?
Yes, it hapends on mobile and PC
Mike
#4
Go to the top-level and press F12 in your browser - then open the Console tab in the inspector, then manage the instance. Do you get any errors there?
Mike
#6
Run ampinstmgr --nocache upgradeall
Mike
#8
What’s the output of df -h
Mike
#10
Show me the full output of:
ampinstmgr --debug --nocache upgradeall
(c) Microsoft Corporation. Alle Rechte vorbehalten.
C:\Users\amp>ampinstmgr --debug --nocache upgradeall
[Info] AMP Instance Manager v2.3.2.4 built 22/02/2022 10:58
[Debug] Loading instances from C:\AMPDatastore\instances.json...
[Debug] Loaded 5 instances.
[Info] Stopping Instance: 'AMPInstance1-ADS'
[Info] Stopping instance AMPInstance1-ADS...
[Info] Waiting for instance to stop...
[Info] Instance AMPInstance1-ADS has stopped.
[Info] Upgrading instance AMPInstance1-ADS
[Info] Skipping cache and downloading fresh copy...
[Info] Downloading AMP from https://cubecoders.com/Downloads/Release/AMP_Latest_Release.zip...
[Debug] Downloading https://cubecoders.com/Downloads/Release/AMP_Latest_Release.zip, saving to C:\Users\amp\AppData\Local\Temp\tmp5497.tmp
[Debug] Moving C:\Users\amp\AppData\Local\Temp\tmp5497.tmp to C:\AMPDatastore\Instances\AMPCache-2324.zip...
[Info] Complete
[Debug] Saving instances to C:\AMPDatastore\instances.json...
[Debug] Wrote 5 instances.
[Info] Upgrade successful
[Info] Upgrading instance GenossenHut
[Info] Using cached archive: C:\AMPDatastore\Instances\AMPCache-2324.zip
[Info] Upgrading instance AntimaterChemestry
[Info] Upgrading instance CSGO
[Info] Upgrading instance M118
Mike
#12
Do you use Cloudflare or other caching proxy?
i connect Localy To the Webpage With out using any proxy
Mike
#14
In the instance directory for ADS, does the file exist that it’s looking for? It should be in Plugins/MinecraftModule/WebRoot/Plugin.js
yes the file exists⠀⠀⠀⠀⠀⠀
Mike
#16
What user owns it? You can check under the file security properties.
owner: amp (WIN-SERVER\amp)
which is my amp specific user
