ADS01 and Instances no longer start after Failed Upgrade and Attempted fix
OS Name/Version:
Ubuntu 20.04.6 LTS - 5.6.0-1054-oem
AMP version 2.4.3.0 (Decadeus), built 14/03/2023 23:15
Running a selfhosted AMP with one Docker container for a controller and currently one target for hosting images. I’ll refer to them as docker and beast.
Docker was updated to 2.4.3.0 from best as I can guess was 2.4.2.0. I believe though the correct process is to upgrade targets first. From what I saw in the web interface, it was due for an upgrade to 2.4.3.0, so I told beast to.
Before and after the upgrade, docker was not able to talk to beast and I saw failed auth key attempts on beast. I tried to fix it, could not, and made it worse. Now the web interface (ADS01) no longer starts.
Attempting to start ADS01 now gives a lastlog like this:
[04:23:29] [Core Info]            : Starting AMP version 2.4.3.0 (Decadeus), built 14/03/2023 23:15
[04:23:29] [Core Info]            : Stream: Mainline (Release) - built by CUBECODERS/buildbot on CCL-DEV
[04:23:29] [Core Debug]           : Running command line: "/usr/bin/sudo -n bash -c "touch /dev/null"" from ""
[04:23:29] [Core Warning]         : Current time zone is set to EST - It is recommended you switch to UTC+0 to avoid time-zone related issues
[04:23:29] [Core Info]            : OS: Linux / x86_64
[04:23:29] [Core Info]            : CPU: Intel(R) Core(TM) i9-10885H CPU @ 2.40GHz (8C/16T)
[04:23:29] [Core Info]            : RAM: 63949MB
[04:23:29] [Core Info]            : AMP Instance ID: 92298491-3311-49cc-baf6-0b19e97c1f81
The actual output has a little more:
  CubeCoders AMP  💻amp@beast  📁~/.ampdata/instances  ampinstmgr start ADS01
[Info] AMP Instance Manager v2.4.3 built 14/03/2023 21:50
[Info] Starting Instance: 'ADS01'
[Error] Failed to start AMP. Exit code was 0
[Info] This instance failed to start. Run 'ampinstmgr LastLog ADS01' to view it's most recent log.
  CubeCoders AMP  💻amp@beast  📁~/.ampdata/instances  ampinstmgr LastLog ADS01
If I run AMP_Linux_x86_64 directly, I get:
  CubeCoders AMP  💻amp@beast  📁~/.ampdata/instances/ADS01  ./AMP_Linux_x86_64
[04:28:44] [Core Info]            : Starting AMP version 2.4.3.0 (Decadeus), built 14/03/2023 23:15
[04:28:44] [Core Info]            : Stream: Mainline (Release) - built by CUBECODERS/buildbot on CCL-DEV
[04:28:44] [Core Debug]           : Running command line: "/usr/bin/sudo -n bash -c "touch /dev/null"" from ""
[04:28:44] [Core Warning]         : Current time zone is set to EST - It is recommended you switch to UTC+0 to avoid time-zone related issues
[04:28:44] [Core Info]            : OS: Linux / x86_64
[04:28:44] [Core Info]            : CPU: Intel(R) Core(TM) i9-10885H CPU @ 2.40GHz (8C/16T)
[04:28:44] [Core Info]            : RAM: 63949MB
[04:28:44] [Core Info]            : AMP Instance ID: 92298491-3311-49cc-baf6-0b19e97c1f81
Unhandled Exception:
System.NullReferenceException: Object reference not set to an instance of an object
  at GSMyAdmin.Core.SetupAuthProvider (GSMyAdmin.Config Config) [0x00015] in <b5681ed5587e43f0853017e6ab190ac4>:0
  at GSMyAdmin.Core.Run () [0x00475] in <b5681ed5587e43f0853017e6ab190ac4>:0
  at GSMyAdmin.Program.Main () [0x00005] in <b5681ed5587e43f0853017e6ab190ac4>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.NullReferenceException: Object reference not set to an instance of an object
None of the instances (all Minecraft related) fully start, looks like they all get errors trying to talk back to Core:
[04:11:00] [Core Error]           : SocketException
[04:11:00] [Core Error]           : [0] (SocketException) : Connection refused
[04:11:00] [Core Error]           :   at Net.Sockets.Socket.Send (Byte[] buffer, Int32 offset, Int32 size, Net.Sockets.SocketFlags socketFlags)
  at Net.Sockets.UdpClient.Send (Byte[] dgram, Int32 bytes)
  at ModuleShared.MetricsInfoPublisher.ScheduleHandler (Object sender, EventArgs e)
I see that many times in the log.
I’m also having a problem logging into any of the instances. May be related.
Any suggestions outside resetting everything? I’m about ready to wipe and rebuild at this rate.
  • Controller was updated, Target was not.
  • Target got updated.
  • Still unable to connect to Target
Some of the commands I ran to try to fix were:
  • ampinstmgr --repairauth
  • ampinstmgr --reactivate ADS01 {key}
  • ampinstmgr --ReconfigureInstance ADS01 (this would not even run)
Aftert I broke it more (nothing starts), I tried:
  • resetting permissions
  • taking a full backup (no real prior backups though)
  • restoring ADS01 from a 2 month old zip
  • Resetting things back
  • running AMP_Linux_x86_64 directly (above)
  • restoring AMP_Linux_x86_64 from 2.4.2.0’s Mainline zip along with Plugins and WebRoot
  • Resetting things back…
  • Finally coming here.
You said you had a controller and a target, but it’s not clear from the logs which ADS log is from which?
All the logs is from the Target. Controller is up and running fine as far as I can tell.
